Do the balls on a high scored cap count towards the possession limit, or is it like In the Zone where stacked cones did not count as possessing?
Edit: I mean when there are balls on the cap, high scored caps are when they are on the side poles. That being said, why place balls on the caps??? I guess I thought the balls scored on the caps, maybe because they’re non scoring objects they do count towards the hoard limit…
According to the rules, a cap can be high scored with a ball on it. The only benefit that I can see from this is that it might be a good way to effectively limit the number of balls on the field since you can’t physically remove them. It would be possible to get them back by descoring the cap, but it would take time; on the other hand, it would take longer for you to place those balls on a scored cap.
