I noticed that the shaft inserts fit perfectly into the v5 motor shaft hole, where they made for this?
Maybe not intentionally, but the shaft inserts are made to fit in 1/4 inch hs axle holes, and the v5 motors are designed to take those shafts direct
The only use I can think of for this is if you put the axel shaft insert into the motor so that your axel has more of it inside of the motor, which I guess could prevent twisting and axel.
If anyone thinks of something cool to do this this please share
Shaft length doesn’t need to be as precise when using a shaft insert in the motor.
It’s much easier to install the motor on a small shaft with the insert since it’s easy to see the hole for alignment.
Much less likelihood of the shaft coming out of the motor and loosing power.
