can you have your robot shift between a high and low gear if the controller is at full power and the wheels are not moving with out using a button?
- Explain more what you mean because I have no idea what you are asking
- Please don’t make multiple threads with the same question
Try using the search bar for “planetary transmission” “differential transmission” “pneumatic transmission” or just plain old “transmission”.
The first one was in an official Q&A, so maybe he/she figured out that normal users can’t respond to those posts.
yes you must switch ratio planetary linear half speed some backward some forward? make sure double A batteries are green good but wheels must move except if H drive then not all but probably use button because otherwise accidental movement. hope this help
