Hello, I made this conversation to help teams trying to make a flywheel. There are 5 main tips,
- Compact. Make the flywheel as compact and as possible so as to keep your bot fast and to conserve space.
- The shroud. I have found that this is the make or break for the robot. The shroud should either be a perfect consistent distance from the center of the wheel OR it should be relatively loose and progressively get tighter until it gives more pressure at the end. Shrouds should be made with vex foam and lexin. (plexiglass or plastic or whatever)
3, Friction. A flywheel is the hardest shooting mechanism to make because the wheel needs to have the most minimal points of contact and needs to have no drag so that it can spin at max speeds. To do this use bigger gears and drill holes in the metal so that the actual shaft for the wheel will only have 2 points of contact on the metal. - Cartridges. Use turbo, it’s superior.
- Wheels. Some say more contact on the ball is best but that is a common miss conception. Having one wheel will create less weight on the motors causing more speed, less drag, and less charge up time. I prefer double wrapped rubber bands around those patterned flat tires.
I hope that this list of guidelines might help teams in the future because making the shroud alone for my team took like 4 or 5 hours to perfect. Good luck in the remaining season!!
