Single Sprocket Intake vs. Double Sprocket Intake
Some teams are using a roller intake for their traybot that uses one sprocket with tank tread flaps on each side. Some teams are using two sprockets with tank tread flaps connected by chain on each side.
I have not yet seen a poll on this yet, so what is your team using.
  • Single Sprocket Roller
  • Double Sprocket Roller
0 voters
Also, which design do you think is better.
I would say 2 sprockets, because they can grasp the cube better when you are putting it in a tower (if you have a complex tray). They also give you more compression.
@RoboCatz
same, but I have seen other teams use only one sprocket on each side, even good Chinese teams.
Even the VEX design uses two:
the “VEX” design… right
Hey… the v5 clawbots in reveal videos are godly, I wonder what this will do… proceeds to levitate above the field
I honk the design that vex made is pretty good, the intake rollers that don’t have flaps use standard chain to reduce weight. @DRow willl there will build instructions for it? And if so when will they be released?
@Doctortictac
lol that reminds me of the clawbot in the Starstruck game reveal that levitated to hang from the pole
How 'bout they don’t make instructions to build stuff and we just design ourselves.
Yep exactly⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀
I don’t use that type of intake for my tray, no leekz
In some of the older animated reveals, the robots actually did levitate.
Why was that, what software was used to make the levitating effect?
Just look up First VEX Challenge and you get all the answers.
Are you the one who’s been dropping hints of your cascade bot?
Because you make me want to hack your camera to see it
Jk I dont even know how that would work
No, I don’t have a Cascade lul, I did last year in early season tho. This year I have a tray with a, different, intake
A little birdy told me it would not be released…
I think your talking about @Deicer
Quick update on this. The Build Instructions for the V5 Competition Super Kit Robot, “Stack” are now online. They can be downloaded here:
link.vex.com/docs/vexedr/stack-BI
Add a two stage flipout and maybe even a cascade. With good coding this could honestly make states (maybe even worlds) depending on region.
