How exactly does one go about banding a six bar lift?
I’m not 100 percent sure without pictures but this should help: https://vexforum.com/t/uniformly-tensioned-rubber-band-system-analysis-guide/28402/1
The same way you rubber band a 4-bar lift, imagine if you have two 4-bars joined at a corner. You can rubber band them individually or you can do two sets of rubber bands. You could (in theory) rubber band across the middle vertical post towards the front post ? 4-bars are the easiest to band - so if you have one of those, band that.
