Since the manual didn’t have one, I rendered an image that could be used for a skills route template. It displays the correct skills starting positions for all the balls and is top-down to best facilitate drawing.
wait, is the skills field layout different to the teamwork field layout?
Yes.
From VRC hub app rule book
looking at the skills rules, we obviously play scoring for red, but, if we remove the blue ones, do we earn a point? also assuming no red is scored, does that put you at a negative score or just zero? and one point added for every blue ball taken out?
unfortunately not. you only need to descore 3 blue balls to make room for all 15 red. blue balls don’t take away from your score, so no point descoring more than necessary. skills will be maxed out this season.
So can u only score red balls or something weird like that? Also I assume this game’s skills is different and that every color isnt scored as the same color?
The rules spell all this out. Please read them.
that is alot of balls in 1 minute. I’m doubtful teams will max score on skills
15 balls in a minute? that will be maxed, at least for driver skills. if it takes you 2 seconds per ball (which is probably a lot more than it will by end season) you can score all the balls in 30 seconds. leaving you 30 spare seconds for travel time and the descoring of the 3 blue balls. I expect to be able to max out driver skills by my first comp, and I’m bad at skills lol.
Really??
20 characters
huh nice to know
20 chars
