My team and I were researching about preventing our PTC fuse from tripping, and stumbled upon @jpearman 's work of art. Of course, most of you have probably seen it before:
#define MOTOR_NUM ((int) kNumbOfTotalMotors)
#define MOTOR_MAX_VALUE 127
#define MOTOR_MIN_VALUE (-127)
#define MOTOR_DEFAULT_SLEW_RATE 10 // Default will cause 375mS from full fwd to rev
#define MOTOR_FAST_SLEW_RATE 256 // essentially off
#define MOTOR_TASK_DELAY 15 // task 1/frequency in mS (about 66Hz)
#define MOTOR_DEADBAND 10
// Array to hold requested speed for the motors
int motorReq MOTOR_NUM ];
// Array to hold "slew rate" for the motors, the maximum change every time the task
// runs checking current mootor speed.
int motorSlew MOTOR_NUM ];
task MotorSlewRateTask()
int motorIndex;
int motorTmp;
// Initialize stuff
for(motorIndex=0;motorIndex<MOTOR_NUM;motorIndex++)
motorReq[motorIndex] = 0;
motorSlew[motorIndex] = MOTOR_DEFAULT_SLEW_RATE;
// run task until stopped
while( true )
// run loop for every motor
for( motorIndex=0; motorIndex<MOTOR_NUM; motorIndex++)
// So we don't keep accessing the internal storage
motorTmp = motor motorIndex ];
// Do we need to change the motor value ?
if( motorTmp != motorReq[motorIndex] )
// increasing motor value
if( motorReq[motorIndex] > motorTmp )
motorTmp += motorSlew[motorIndex];
// limit
if( motorTmp > motorReq[motorIndex] )
motorTmp = motorReq[motorIndex];
// decreasing motor value
if( motorReq[motorIndex] < motorTmp )
motorTmp -= motorSlew[motorIndex];
// limit
if( motorTmp < motorReq[motorIndex] )
// finally set motor
motor[motorIndex] = motorTmp;
// Wait approx the speed of motor update over the spi bus
wait1Msec( MOTOR_TASK_DELAY );
When we added this into our code, we saw a huge improvement on our lift. Now, we just have two more questions, is there any variable we can play around with, and kind of ‘tune’ to our specific application that is in the definition block, because it does still stall a little (although less often). Also, is there a way that we can write this code so that it only applies to our one lift motor, instead of everything?
Thanks
