Slip Gear
Just an idea, but with the varying power of flywheels based on battery voltage, has anyone thought about the slip gear?
https://lh5.googleusercontent.com/-daBATQrB-Qk/VTv8PE2s95I/AAAAAAAAA2I/TxNLhmNll0A/w120-h132-no/slip%2Bgear.png
Neat design, can you explain how this would work with a flywheel?
I’ve built similar gears for catapults before, where I want to let go of a bunch of tension, but that’s it.
I think he means use slip gears on catapults instead of flywheels
Catapults or “spring” launchers. (“springs” are elastics)
