We have a arm that is acting more like a catapult. Is there any way to slow the motor down during driver control without changing the physical motor?
It will be something like
set velocity 40%
I didn’t do syntax if you are text-based
If in block, it will be a block that with say
Set [motor] velocity to --% set it to 35 or 40% to slow it down. Go down further if still too much.
We are using C++, thanks anyway
Ah, youtube probably knows if you have access to it, but it will be something about set velocity.
I will take a look. 20 characters
Ok, if you can’t find help, I will capture my sister and force her to write the line of code.
Don’t add this line in the middle of your driver control function. just the 1st line.
I use block coding usually because I am gonna wait till high school to learn C++ and C#. I just used the built in code viewer. But thank you for the info!
