How do I slow my motors in Driver Control? I have a turret for a tank that I need to slow down. were using V2 for this project. can anyone help? I need an answer/solution soon since our pep-rally is on Wednesday morning
- you can gear it down (using physical gears)
- you can move the joysticks “slowly” (drive better)
- you can program the output to be 1/2 of the joystick (twice as slow) if you have enough torque (needs programming background)
- you can use a half dead battery if you have LOTS of torque
(#4 was a joke, but if you do not have time to do 1, 2, or 3 then you can attempt #4)
Here is how you can implement this Murdomeeks method 3.
I assume your existing turret programming looks something like this in EasyCv2.
MotorRcControl(t#,chan#,motor#,inv); // control turret
To lower the speed of the turret with programming, you’ll need to split this into 2-3 pieces; get the TX value to a variable, modify the variable, apply to motor.
EasyCv2 uses motor speed range 0 (ccw) to 127 (stop) to 255(clockwise),
so you can’t just divide the speed by 2 (or other value) because that will make 255 (full-on) turn into 127 (stop).
So subtract 127 first, then scale, then re-add 127.
Add 2 Variables:
unsigned char t_val 0;
unsigned float scale 1.8; // change this to be whatever scale you need
Comment out previous MotorRcControl(t#,chan#,motor#,inv);
Add these three lines instead
t_val = GetRxInput(t#,chan#);
t_val = ((t_val - 127) / scale ) + 127; // assignment statement pulldown
SetMotor( motor#, t_val );
Good luck with your demo.
