We just hosted our first Tournament one week ago and intermittently throughout the day the Smart Field Controllers lost connection with Tournament Manager. I was so disappointed because I really tried to follow all the instructions here: https://kb.roboticseducation.org/hc/en-us/articles/8497714209687-Smart-Field-Control
Our Setup:
3 Raspberry Pi 3Bs for competition fields
-Each with a 50 ft Ethernet connection to router
-Each with a 3 Amp power supply
-Each with a Smart Field controller that was purchased in the last year
-Latest firmware
-Updated the Raspberry Pi using TM on the Laptop (using the automatic function, not manually)
-Power cable running around one side of the field, Ethernet running around the other.
-Amazon basics USB Cable 3ft between Pi and Field Controller.
Power to Field Controllers was the Charger it came with.
Wired Ethernet to Laptop
We had about 20-30 disconnections in an 8 hour day. The teams would come to the field and it would not see the robots. Then we would unplug the USB from the Pi plug it back in and often times that would fix it. At the end of the day we often found we had to power cycle the Smart Field Controller and the Pi and then it would be running again. This seemed to happen more at the end of the day than the beginning of the day. There was a little more time between matches then with the elimination matches. Our head ref was the one who taught us that unplugging the USB from the Pi and then replugging it in would often fix it. He had apparently had this issue at past tournaments.
Our wireless Pis on the skills fields did not have this problem. Made me want to switch our main fields to wireless. Skills fields were run off of brains instead of Smart Field Controllers.
We have another tournament in February and I’d like to avoid these issues. Does anyone have any suggestions?
Also, I saw this post, but didn’t want to hijack it with my own issue: [Smart Field Controllers losing Connection with Tournament Manager]
