Smart Motor 228-2560
Hello, can I turn the engine faster than its maximum speed, whether it burns? For example using the other engine (228-4127 Tooth Gear Pack). Will it is harmful during acceleration 2-3 times? (Google translated)
If the motor has been told to run at a given speed, even only 1%, the PID algorithm will try to keep the motor at exactly that speed so if you try to overspeed it, the motor will try to compensate and keep at the slower speed. The only circumstance where the motor can be freely turned at any speed is if the motor speed is set to zero and the motor is set to coast mode.
I guess if you try hard enough, the motor will break or at least overheat.
With IQ, it is not possible to turn the PID function off.
