SMC part numbers?
Does anyone have a list of part numbers for the VEX compatible parts from SMC? We want to build a new robot for worlds, but just getting to California is more of an expense than we planned. We have already decided on a design and buying the pneumatics will leave little left over for the other materials we need. We are a new 1 member home school team so we don’t have a surplus of materials from previous years to use.
Thanks!
The part numbers are the same as found on the Kit pages.
For the single acting cylinders:
Tire Pump Fitting - Shraeder Valve With 4mm Tube Fittings - 8090410075
Reservoir - Reservoir, 1-1/2" X 4", w 1/8"NPT & M5 port - US14227-S0400
Pressure Regulator - Mini Regulator w/ 4mm Fittings - A-474-0000005
“T” Fitting - “T” Fitting for Valves - KQ2T04-00
Cylinder, Air Push, Spring Return - Single Acting Spring Return Cylinder 10mm Bore - NCJ2D10-200S
Solenoid, On/Off - 3/2 Solenoid Valve, 5VDC - SY113-SMO-PM3-F
Fitting for Valves - Fitting 4mm Tubing x M3 Thread - KJS04-M3 or KJL04-M3
Fitting for Reservoir - 1/8 X 4mm Male Connector To Reservoir - KQ2H03-34S
Fitting for Cylinders - M5 Male Connector for Cylinders - KQ2S04-M5
Tubing - 4mm X 1696mm Length Tubing - TUO425B-X81US1696
For the dual acting cylinders:
On/Off Switch - Finger Valve - VHK3-04F-04F
Cylinder, Bi-directional - Dbl Acting Cylinder 10mm Bore - NCJ2D10-200
Solenoid, Fwd, Reverse - 5/2 Single Solenoid Valve, 5VDC - SYJ3120-SMO-M3-F
Flow Meter - M5 elbow meter out flow control 4mm tubing - AS1201F-M5-04T
Note that you cannot purchase the solenoid cable or the custom metal from an external vendor that comes with the kit from VEX. You can purchase the solenoid cables from VEX separately and you can rig your own mount by purchasing plus gussets.
Thank you so much! I hate buying parts elsewhere since I have many friends that work for IFI, but when it comes down to buying from SMC or doing without then I am going to have to go with SMC…
