SnapCad to Stl
I have a snapcad document file and was wondering if it’s possible to convert it to an Stl?
Yes, it is possible. Here is a topic on this very same forum with the solution:
For future reference, there is a search bar in the upper-right-hand corner of the VEXForum. It can help you find a solution to a given issue faster than waiting for a response.
Yes, I have already seen this post however it it not one piece it’s a fully assembled design that I now want to export and is only available as a snapcad document not a step file.
In that case, you can use an online converter to make snapcad’s .ldr (also known as LDraw) file to a .step file.
