Quick question for the sniper-capable robots out there. At what position do you prefer standing at for the best perspective- Back square or front square? Or is there no difference between these?
I prefer back since it is easier to line up
With a flywheel, I’ve found how it’s much easier to line up the shots from the back especially by using the back wall.
Ideally right behind the platform as it gives the protection you need while not losing as much velocity as the back and not having to be at as much of an exact angle to the flags.
Plus everyone has autons for the front tile that aren’t bad. Back sniping is really the only efficient way to do it. (Unless your partner has no auton or is a cap stacker.)
