Software to filter out signal spikes?
I’ve just been wondering if there’s not a simple way to help avoid spurious signals from causing, say, a While loop from ending too soon. I don’t know if there is some kind of digital filtering that goes on behind the scenes with the Cortex, etc. so I was wondering if some software might be able to help with it if there is not.
I thought about the following, written kinda in pseudocode but it seems somewhat weird. :confused:
Would something like this make sense to use?
Basically what I think this would do is cause a While loop to check multiple times to make sure the sensor actually reached its value and wasn’t faked out by a signal spike.
SafeCount = 10;
Counter = 0;
While(SensorValue<TargetValue  OR  Counter<SafeCount)
     Turn the motor on;
      If(SensorValue >= TargetValue)  //If the desired condition was met....
            Counter = Counter + 1;  //...then start counter.
            Wait 1 millisecond;
  Turn the motor off;
Sure, I wrote something to get around a pot occasionally giving a bad value for the kids last weekend.
task
turntableTask()
   // attempt to fix the bad pot
  int lastPot = SensorValue[pot];
  if( turnTablePosition > SensorValue[pot] )
    while((SensorValue[pot] < turnTablePosition) && (lastPot < turnTablePosition))
      motor[TurnTable] = -50;
      wait1Msec(25);
  else
    while((SensorValue[pot] > turnTablePosition) && (lastPot > turnTablePosition))
      motor[TurnTable] =  50;
      wait1Msec(25);
  motor[TurnTable] = 0;
  turnTableDone = 1;
That’s only a one sample delay but can be enough sometimes to fix a flakey pot.
sometimes I use an IIR (infinite impulse response) filter, here is an example filtering current in the smartMotor library.
    // simple iir filter to remove transients
    m->filtered_current = (m->filtered_current * 0.8) + (i_bar * 0.2);
Very cool. Thanks very much! :slight_smile:
