I have a problem with programming an ultrasonic sensor that is completely baffling me, I hope someone knows whats going wrong.
Essentially I’m using it for a simple while statement for reversing, I have done this a couple times before, but this time I found the ultrasonic sensor wasn’t showing up in the debugger window, I tried a few different obvious things (checking ports and config code and such) yet it still didn’t work. So I created the simplest code I could think of to try to diagnose the problem, and I found I could get it to recognise the sensor if I didn’t include any other sensors in the setup. Here is the code I tried:
This works:
#pragma config(Sensor, dgtl4, sonarSensor, sensorSONAR_inch)
#pragma config(Motor, port8, Right1, tmotorVex393HighSpeed_MC29, openLoop, reversed)
#pragma config(Motor, port9, Right2, tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor, port2, Left1, tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor, port3, Left2, tmotorVex393HighSpeed_MC29, openLoop)
task main()
wait1Msec(2000);
while(SensorValue(sonarSensor) > 5 || SensorValue(sonarSensor) == -1)
motor[Left1] = -63;
motor[Left2] = -63;
motor[Right1] = 63;
motor[Right2] = 63;
This doesn’t:
#pragma config(Sensor, in1, FrontL1, sensorLineFollower)
#pragma config(Sensor, in2, FrontR1, sensorLineFollower)
#pragma config(Sensor, in3, FrontM1, sensorLineFollower)
#pragma config(Sensor, in4, Back1, sensorLineFollower)
#pragma config(Sensor, in7, ClawSensor, sensorPotentiometer)
#pragma config(Sensor, in8, LiftSensor, sensorPotentiometer)
#pragma config(Sensor, dgtl4, sonarSensor, sensorSONAR_cm)
#pragma config(Sensor, dgtl9, LeftRotation, sensorQuadEncoder)
#pragma config(Sensor, dgtl11, RightRotation, sensorQuadEncoder)
#pragma config(Motor, port4, Leftlift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port5, Rightlift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, Claw, tmotorVex393_MC29, openLoop)
task main()
wait1Msec(2000);
motor[Left1] = -63;
motor[Left2] = -63;
motor[Right1] = 63;
motor[Right2] = 63;
I really can’t tell why there should be any difference.
Also now its only displaying the 2 quad encoders in the debugger.
Thanks.
