Good afternoon, I’m building a model in the next top:
http://www.vexiqforum.com/forum/main…-pitbull/page2
And how can I not get a good result on “ModKit” if you could help me to put the sources on the “RobotC” any suitable for the line “VexIQ”.
- Operation with the remote control (Press events key).
- Threads. Events.
- Work with the “Gyro, Motor”
- Cycles, conditions. “if case while for until continue repeat esle”.
Any of your sources will be very useful to understand how quickly you need to work with the program “RobotC” Thank you in advance, and if they still have comments this will be just a gift! ))
Hey Valeria~
I found this after a quick search. I can probably find more information on using case or other code examples. Let me know if it helps. ( I don’t mind if you say you it’s too basic or that you can not use it - just trying to find ways to help In a short amount of time!)
Please let me know if this type of resource helps.
Also, do you program your bots in English or Russian?
VEXIQUserGuide2.pdf (3.07 MB)
Any of your sources will be very useful to understand how quickly you need to work with the program “RobotC” Thank you in advance,I found this after a quick search. I can probably find more information.
MBA NRI quota admission
http://admissionq.com/mba-nri-quota-admission/
