So I’m trying to get both intakes plus the spinning elevator system onto one set triggers. I am using VEXCode V5 Blocks, and need help on this. Is there possibly a way to do this?
I do this is RobotC with
if(VexRT(BtnLDown)==1)
setMotor(intake1,-100);
setMotor(intake2,-100);
setMotor(elevator,-100);
else
if(VexRT(BtnLUp)==1)
setMotor(intake1,100);
setMotor(intake2,100);
setMotor(elevator,100);
else
setMotor(intake1,0);
setMotor(intake2,0);
setMotor(elevator,0);
Whoa! @Ravenclaw7621 No need to make more than one topic for the same question. You can just post again on the same topic.
Oh wise and mighty @DRow, no mortal user could fix these threads.
Anyway, this should be a good solution for this particular programming problem I found on another thread. Same logic, just add an extra spin command for the extra motor.
Please use else if
milo (or whatever it is in C)
Thanks!
Wait, I did though! (20 characters)
Nah, you put an if
inside of an else
. There’s an actual command for that else if
Isn’t progaminggramming epic?
