Spontaneous channel switching/dying
We are having an unusual problem with our vex elevation robot. Controls from Rx1 work fine. However, for about one boot out of every four, about 30 seconds after teleoperated mode begins, signals from Rx2 begin to undergo a bizarre, repeated, pattern:
Channel 5 (controlling motors 5 and 6) does not work
Channel 4 (controlling motor 7) instead controls motor 8
Channel 3 (controlling motor 8) does not work.
After about 45 seconds of this, the robot returns to normal.
Rx2 Light remains on at all times, and no code error light flashes
This problem has never occured under tether, but its occurence is inconsistent enough that i could believe that this is a coincidence
Any suggestions as to why this might be/how to solve it?
I’d suggest reloading the master code (the .bin file) and then reloading your code (.hex file) and trying it again.
I’ve seen very weird stuff that was solved by reloading the master code.
Did reloading them master code and your user code help?
If no please post the user code here and we’ll take a look.
Foster
Either the master code, or the discovery of some slight metal contact with the Rx2 antenna, seems to have helped.
Thanks :slight_smile:
