Whenever i put extenders on the standoff, the extender never comes off, any tips for taking them out?
I usually stick a screwdriver in the other end, hold really tight on the extender, then push.
I use the another vex piece to take it off, like a 1x beam. Hopefully they arent super stuck because then you may need to use something like plyers
Lab 2 - Loop, There It Is! - Removing Standoffs from Mini Standoff Connectors | VEX Education This can help you if you are using this type of extender
Or you can use this: Pin Tool - VEX Robotics
