My team can’t get our standoff size in the back right. We have a 4-inch flywheel running through the middle of a channel. Is there a size that will work best with this.
you can use spacers between the head of the screw and the end of the standoff to fine tune the length of the standoff.
what are u using the standoffs for?
this is what i do when a standoff doesn’t fit perfectly.
I use washers. I don’t trust a full spacer.
we use drilled out standoffs as spacers
I use the magical, but strenuous power of meticulous tuning
