This could be a problem at worlds, because it will be full of new game objects.
But it comes down to,
Will it affect the game
No
Will it really affect anyone
Probably not in a way that would affect the outcome of matches
There is a high probability that they will fix it by worlds anyway
Also, Worlds is in a huge building (I mean really big, MS, HS, and Vex U were all in the same room), so it will basically be open-air. That should help a bit.
Just an average air purifier won’t help you. You at least need one of these air purifiers to do the works. A good air purifier don’t just need HEPA, it must be a certified True HEPA filter, along with a carbon filter to remove the odors and VOCs.
@chloevanessa This was literally over two years ago… I’m sure its not a problem now.
Just for others with the same problem, @littlebro5 :D. Because I don’t think the solution of leaving them outside is okay.
@chloevanessa nobody will have this problem because it was * two years ago *
@chloevanessa Despite this being an old problem, there may be still some people curious about a good solution. Thanks for positively contributing to this forum.
@chloevanessa This is helpful and all but really not needed. Reviving dead threads doesn’t really help anyone, especially if they’re threads relating specifically to old games.
@DRow I think all that needs to be said has been said, could you please lock the thread?
Thank you!
