hay I was wondering what robots are all useful to use in this compition
1st step is to probably just look up some videos. if you’re new to this, then I would recommend building something simple.
If you are just starting out, I would suggest building the hero bot. This will give you a good start, and you can improve by getting ideas from peers or other teams or, as @Zach_41819 said, watching some videos or tutorials. Good luck!
The hero bot is a start, but look up some tutorials and look at some other team’s robots for inspiration. But most people are using a similar general design: a clamp or scoop to grab the mobile goal at the back, then use a flex wheel intake and conveyor belt system to carry the rings to it. You could do something else, but this is probably the most efficient method.
