String size clarification
R7 e contradicts itself as measurements work as between 1/8 and 1/4 means any measurement between 1/8 and 1/4 but not 1/8 or 1/4 but then it says a minimum of 1/8 which would mean it should say 1/8 to 1/4 instead of between 1/8 and 1/4
So should i assume they used the wrong word and its 1/8 to 1/4 or should i assume the correct word was used and the second part unintentionally contradicts itself which would mean that 1/8 is too small?
Many Q and A strands cover this, but it is just worded wrong. Any thing BETWEEN 1/8" up to 1/4" is legal.
Technically, it is anything between 3mm (0.118") and 1/4" inclusive
Thats not how measurements work though, nor is that how “between” is defined
Here is the Q&A regarding string diameter:
https://www.robotevents.com/faqs/27/questions/1271
I hope this clarifies it for you.
Here is the Q&A regarding permissible string modifications:
https://www.robotevents.com/VRC/2022-2023/QA/1275
@Mentor_355U is correct in his response following what the GDC has clarified in Q&A.
