When you go to state with a robot this is both out of dimensions as well as out of expansion limits.
ITZ
ITZ
Believing a sister team when they said their DR4B (which I was conceptually involved in) was working great. Needless to say, we were throwing zip ties everywhere before inspection the next day trying to stop skipping due to poor(ish) build quality.
(How do you fix a dumb problem? With an even dumber solution!)
Had battery problems and would only plug in batteries just before matches. Needless to say, we entered several matches confused as to why our robot wasn’t working (we didn’t plug the batteries in).
We had a good laugh at it though XD
Last year I tried to put axles on without an bearing blocks.
when i started vrc i didnt know how 2 tighten nylock and thought it was useless so my partner tried to drill through it to make spacers out of them and almost started a fire in my bacement
Driving a steel bot on a low friction surface, and using that to gauge the robot’s abilities.
This was at state. It was my first robotics competition because I was too busy during past robotics competitions to go. anyway the guy who greets everyone before competition starts asked in joking manner that I did not pick up if this was anyone’s first competition this year. well being the idiot I am I raised my hand and the whole crowd all turned to me like he has to be joking
Impaled a drive shaft into my hand.
Someone on my team melted through a pair of safety glasses with the sparks from a Dremel.
We filed down a driveshaft then smacked to files together causing sparks. Big brain time
i wore a pickle rick costume to a competition for no reason
We were named The Titans. We wore a safari hat and a grey shirt and jeans.
Some of my teammates were wrestling at night during an oversea competition
My first attempt at a build was a DR4B… Needless to say, it wasn’t pretty xD
We tried to build an all steel DR4B our first year in vex. The stripping gears sounded like a fork in the garbage disposal.
with a cat in it too
I’ve done a full steel DR4B. Except I made it work. It was ludicrously slow for a DR4B, but I made it work. While it was admittedly awful, I’m still glad I did it so that I had experience when I went to build other DR4Bs later on.
Ours (@4810N) did work… but it sounded like sticking 8000 paperclips in a blender. A week ago I managed to get a nut on the screw backwards, and we also bought a bunch of field tiles that ended up 6 inches short of 12’x12’, which resulted in us spending a bunch of time fixing it and cutting tiles. Its great.
No bearings, and a 12t plastic instead of metal… on our puncher…
Building a dr4b which used 35 hole long arms. I bent all the axles in it, which made me mega sad as I had to trash all 8 axles
