The VEXplorer is a neat little platform, but unfortunately it lacks the programmability of the original vex platform. I spent a weekend building an interface that would allow PC control of the VEXplorer as a serial device.
This will void your warranty etc etc.
Basically you need to take apart the VEXplorer remote, remove trace 20 on the ELAN microprocessor chip. Solder a wire to this point. Now this point is looking for a standard futaba PPM Rc signal. (20 ms frame with ~300us pulses)
Details are given here: http://profmason.com/?p=508
Generate the appropriate pulse stream and feed it into this point. Any standard microprocessor can be programmed to take a serial input and generate the appropriate PPM stream.
For a writeup of the entire project and video of the VEXplorer navigating autonomously using the video camera as a sensor go to:
[profmason.com - This website is for sale! - profmason Resources and Information.
[http://profmason.com/?p=513
