I’m trying to use the PlaySoundFile() function and have not had any luck. I am able to get some sound, but it is always completely garbled (either a high-pitched whine, or random clicking). I’ve tried a variety of sample files from this site as well as a few others to no avail.
I’m running current ROBOTC and have current firmware installed on the Cortex. PlaySound() and PlayTone() do produce good quality sound, so I know my use of the SP port is correct.
Is PlaySoundFile() expected to work, or is it known to be broken?
Is there a specific encoding of WAV files that does work?
I’ve gotten it to work by choosing simpler WAV file encodings.
So far, I’ve had luck with 8KHz Mono samples, either Linear-PCM or µ-Law encoded. I’d still love to see a list of supported formats.
Even better, the File Manager window could either transcode to a supported encoding, or at least warn if an incompatible encoding is being downloaded. It has a checkbox to normalize the sample volume, so it appears to already be modifying the WAV data on the way down to the Cortex.
Thanks for the feedback, and I’m glad you got it working. To answer your initial question… only certain types of WAV files will be supported – i.e. monophonic with PCM uncompressed encoding (and perhaps ADPCM compression as well).
