So, I have this code:
# Project: VEXcode Project
# Author: VEX
# Created:
# Description: VEXcode V5 Python Project
# Library imports
from vex import *
while True:
# Stop all motors if axis 3 is at 0
# if controller_1.axis3.position() == 0:
# FrontLeft.stop()
# FrontRight.stop()
# BackLeft.stop()
# BackRight.stop()
if controller_1.buttonL2.pressing():
Arm.spin(FORWARD)
if controller_1.ButtonR2.pressing():
Arm.spin(REVERSE)
if controller_1.ButtonL1.pressing():
Intake.spin(FORWARD)
if controller_1.ButtonR1.pressing():
Intake.spin(REVERSE)
if !(controller_1.ButtonL2.pressing() || controller_1.ButtonR2.pressing()):
Arm.stop()
if !(controller_1.ButtonL1.pressing() || controller_1.ButtonR1.pressing()):
Intake.stop()
# Move forward/backward
if controller_1.axis3.value() != 0:
FrontLeft.set_velocity(controller_1.axis3.position(), PERCENT)
FrontRight.set_velocity(controller_1.axis3.position(), PERCENT)
BackLeft.set_velocity(controller_1.axis3.position(), PERCENT)
BackRight.set_velocity(controller_1.axis3.position(), PERCENT)
FrontLeft.spin(FORWARD)
FrontRight.spin(FORWARD)
BackLeft.spin(FORWARD)
BackRight.spin(FORWARD)
# Move left/right
if (controller_1.axis4.value() > 10 || controller_1.axis4.value() < -10):
FrontLeft.set_velocity(controller_1.axis4.position(), PERCENT)
FrontRight.set_velocity(controller_1.axis4.position(), PERCENT)
BackLeft.set_velocity(controller_1.axis4.position(), PERCENT)
BackRight.set_velocity(controller_1.axis4.position(), PERCENT)
FrontRight.spin(REVERSE)
BackLeft.spin(REVERSE)
# Move diagonally
if ((controller_1.axis3.value() > 10 && controller_1.axis4.value() > 10) || (controller_1.axis3.value() < -10 && controller_1.axis4.value() < -10)):
FrontLeft.set_velocity((controller_1.axis3.position() + controller_1.axis3.position()/2), PERCENT)
BackRight.set_velocity((controller_1.axis3.position() + controller_1.axis3.position()/2), PERCENT)
# Move diagonally
if ((controller_1.axis3.value() > 10 && controller_1.axis4.value() < -10) || (controller_1.axis3.value() < -10 && controller_1.axis4.value() > -10)):
# Turn
if controller_1.axis1.value() != 0:
FrontLeft.set_velocity(controller_1.axis1.position(), PERCENT)
FrontRight.set_velocity(controller_1.axis1.position(), PERCENT)
BackLeft.set_velocity(controller_1.axis1.position(), PERCENT)
BackRight.set_velocity(controller_1.axis1.position(), PERCENT)
BackRight.spin(REVERSE)
wait(20, msec); #Sleep the task for a short amount of time to
#prevent wasted resources.
Whenever I download and run the program, I get this error message:
“Traceback (most recent call last):
File “userpy”, line 56
SyntaxError: invalid syntax”
I don’t understand why, that line is typed exactly how it should be. Can anyone help me?
BTW line 56 is the last line of the set velocity block in move left/right
