Task Spilt In Easy C???
I was wondering if there is a task spit function in easy c. i want to have two seperate loop function run and terminate independently of each other is this possible? and if so how? plz help we have a competion really soon and wihtout this we have no atonomous!
Unfortunately, under normal circumstances the processor in the Vex controller cannot multi task. But, you could use a timer to run two loops concurrently.
void Autonomous ( unsigned long ulTime )
      unsigned long Timer1;
      StartTimer ( 1 ) ;
      // You cannot use a "WAIT" statement with this setup it will stall the loop
      // You can create additional timers with a user code block StartTimer ( 2 )
      // and GetTimer ( 2 )
      while ( 1 )
            Timer1 = GetTimer ( 1 ) ;
            if ( Timer1 >0 && Timer1 < 10 ) // Loop1
            else if ( Timer1 > 11 && Timer1 <21 ) // Loop2
            else if ( Timer1 > 22 )
                  PresetTimer ( 1 , 0 ) ;
