I keep getting compile errors when setting up tasks in the competition template. The following code works just fine without the template. Could someone help me figure out where to set up the tasks in the template? Much appreciated.
task drive () //driving program to run parallel to lifting and delivering
while (1==1)
motor[rightMotor] = (vexRT[Ch2]);
motor[leftMotor] = (vexRT[Ch3]);
task conveyer() /*task conveyor runs the conveyor belt when button 6U is
pressed and runs backwards when 6D is pressed*/
while (1==1)
while (vexRT[Btn6U]==1)
startMotor(conv1, 127);
startMotor(conv2, 127);
while (vexRT[Btn6D]==1)
startMotor(conv1, -127);
startMotor(conv2, -127);
stopMotor(conv1);
stopMotor(conv2);
task main() //task main is the lifting program
StartTask (drive);
StartTask (conveyer);
SensorValue[encoder] = 0;
while(1==1)
while(vexRT[Btn5U] == 1) //high goal
if(SensorValue[encoder]<=1200) //holding pattern for high goal
startMotor(lift1,127);
startMotor(lift2, 127);
else
stopMotor(lift1);
stopMotor(lift2);
while(vexRT[Btn7U] == 1) //go to medium goal
if(SensorValue[encoder]<=800) //holding pattern for medium goal
else
stopMotor(lift1);
stopMotor(lift2);
while(vexRT[Btn7L] == 1) //go to low goal
if(SensorValue[encoder]<=360) //holding pattern for high goall
startMotor(lift2,127);
else
stopMotor(lift1);
stopMotor(lift2);
while (vexRT[Btn5D] == 1) //lower the lift
startMotor(lift1, -50);
startMotor(lift2, -50);
stopMotor(lift1);
stopMotor(lift2);
} //end of forever loop
} //end of task main
