Hey, i have years of experience with vex programming but switching over to an iPad and iPad cant use text and the blocks are all different now so i was wondering if someone could help. We’ve got an autonomous and tele-op, the autonomous works but the teleop has problems
First the robot wont drive with driver control, we set up the drive base in the program but it just doesnt move period, we’ve tried all sorts of stuff. The drive base does work and we can give it commands like drive forward for 100mm but nothing for teleop.
Second one motor wont respond to speed commands. We have two arms with large gear ratios to lift scoring goals, and it lifts just fine, (both are connected to one trigger and bumper). But when we lower the arms one goes at max speed and the other goes at our slow speed. Both arms have the same code, same gear ratios, both are red gear boxes, and same setup in the motor menu. Any ideas?
Thanks!
