Tell me about your latest and best XDrive / Holonomic drive base
Across the years in both VRC and VIQ I’ve built a number of Holonomic Drive bases. My all time VRC favorite is the large C-Channel frame with the drives as being motor modules that are easy to swap for repair. I don’t know the original design, mine is a variation of the Vexmen one.
On the VIQ side, I presently have two, the one for just demoing the drive concept is built on two of the “rise above” plates with the motor sandwiched in between. The small format makes it easy to transport, but there isn’t any space to add a game manipulator, the brain takes up a lot of real estate. I’ve considered a third layer, with the brain being sandwiched. But that makes getting to the buttons and battery replacement a new set of issues to work around. Holonomic drives really want to have the weight balanced on all the wheels.
The other one is a cross with a heavy gusseted crossover at the center. The arms are 2x20 “boxes” with a flat plate at the outer end. The plate is offset so that the motor sits under the arm, and I use the single motor support cap Smart Motor Mount Add-On Pack - VEX Robotics to connect the rear of the motor to the box arms. It works well as a demo platform, but it really screams for support on the ends.
In the hunt for a 2026 design to demo I came across this one from Caution Tape - 8309T - X drive - It has motor modules and a lot of space in the center to put field object manipulators.
There is also Ultra Low & Fast X-Drive Chassis for VEX IQ by 839A that was one of the house bots for their annual battle bot setup. This has some appeal, it looks like I could drive it into a wall (showcasing my amazing lack of hand / eye control) without it breaking.
Onshape has a pretty nice VEXIQ X drive base (scroll down to about the middle of the page). It would be a great example as a 1x build (hey it could be the start of the winning Rapid Relay in 1x parts contest
Of course I could go for this uber small version that was built for Squared Away by team 5580 (Look I used the search feature in the VEX forum!)
In the process I found Xander’s IQ quadruped robot that may end up being a build for another time, but not what I’m after.
So VEXIQ roboteers, post a picture of your favorite (and best) Holonomic drive base that I can reproduce and use as my 2026 demo example. Or design a new one. You are not constrained by parts choices, I pretty much have anything you can think to use.
Thanks!
(Oh and I do have a third VIQ holobot, it’s a 3D printed wonder designed and built by Cody Smith. Once VIQ is allowed 3D printing I’ll bring it out. )
Well, it may not fit the category, but my team has made a H-Drive that uses 4 motors.
This is because we have two h-drive wheels that can spin independently for true zero point turning.
Are the two middle H wheels face to face or side by side?
Maybe a picture?
You are correct though, not quite what I was looking for.
When I built my drive base, I found two ways of doing it. Of setting the motors from the chassis by 45 degrees with the green parts. or offsetting the entire robot by 45 degrees by the green parts again. The second one for me is a lot easier to build and stronger.
Ok, lost here, what are the green parts?
face to face. Sorry I don’t have any good photos.
Face to face was descriptive enough. Had you said they are 90 degrees from rack other at an offset of 45 degrees from the outside wheels, I would have needed a picture and code. I’ve seen heavy robots do face to face centers to translate.
Ok, a nice side chat, so do the rest of you have X drive bases you are excited about?
Sorry.
They are IQ gen 2 things, they are the 45 degree angle peices
I have a X drive that ha no special angle . Basically a square that in an x drive config. I’m planning on making it a cata-puncher.
please explain. do you mean a four wheel h-drive but face-to-face wheels super far apart? or I am blanking or something. but what? also
what does that even mean?
please tell. (maybe im just dumb)
no. it is a mash of coveyer pucher. it is a x drive
