The bot wont move... Is it the program or the motors? [ROBOTC]
I’m new to programming and I’m trying to program a robot right now and it doesn’t seem to be working. it says there are no errors in the programming, so what did I do wrong? Or is it the motors?
Here’s the code-
#pragma config(Motor,  port2,           FlipA,         tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port3,           WheelR,        tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port4,           WheelL,        tmotorVex393_MC29, openLoop)
task main()
	while(true)
	motor[port2] = vexRT[Btn6U];
	motor[port2] = vexRT[Btn6D];
	motor[port3] = vexRT[Ch2];
	motor[port4] = vexRT[Ch3];
	if(vexRT[Ch3] == 1) //Forwards
		motor[WheelL] = 127;
		motor[WheelR] = 127;
	else
		motor[WheelL] = 0;
		motor[WheelR] = 0;
	if(vexRT[Ch3] == 1) //Backwards
		motor[WheelL] = -127;
		motor[WheelR] = -127;
	else
		motor[WheelL] = 0;
		motor[WheelR] = 0;
	if(vexRT[Ch1] == 1) //Left
	else if(vexRT[Ch1] ==1)
		motor[WheelL] = 0;
		motor[WheelR] = 0;
	if(vexRT[Ch1] == 1)//right
	else
		motor[WheelL] = 0;
		motor[WheelR] = 0;
	//Split between Wheels/Arm
	if(vexRT[Btn6U] == 1) //Up
		motor[FlipA] = 127;
	else
		motor[FlipA] = 0;
check the braces {}, looks like you are missing at least one that would stop the FlipA motor from running.
Thanks for the advice, but my main problem is actually moving the bot. It doesn’t seem to move forward or backwards ;-;.
you have multiple commands sending values to the same motors.
for example, this
and this
	else
		motor[WheelL] = 0;
		motor[WheelR] = 0;
vexRT[Ch3] is joystick and will returns values from -127 to +127, not sure what the intent of this code was.
if(vexRT[Ch3] == 1)
Oh, so to fix it should I put a else if statement rather than a else because they are both true???
try something simpler to start with, perhaps this.
task main()
	while(true)
	motor[port2] = (vexRT[Btn6U] - vexRT[Btn6D]) * 50;
	wait1Msec(20);
Alright, will do. Btw, what’s the purpose of subtracting and using different operations on the motors when declaring it?
I have tried this just now and it doesnt work :/.
