Here is the main file where the function is called.
#include "vex.h"
#include "display-button.h"
#include "autons.h"
#include "functions.h"
// competition Competition;
using namespace vex;
// collect data for on screen button
typedef struct _button {
int xpos;
int ypos;
int width;
int height;
bool state;
vex::color offColor;
vex::color onColor;
const char *labelOff;
const char *labelOn;
} button;
// Button definitions
button buttons[] = { //what does this array do?
{ 30, 30, 60, 60, false, 0x000000, 0xCBC3E3, "LSim", "LSim" },
{ 150, 30, 60, 60, false, 0x000000, 0xCBC3E3, "RSim", "RSim" },
{ 270, 30, 60, 60, false, 0x000000, 0xCBC3E3, "LHard", "LHard" },
{ 390, 30, 60, 60, false, 0x000000, 0xCBC3E3, "RHard", "RHard" },
{ 30, 150, 60, 60, false, 0x000000, 0xCBC3E3, "WinPo", "WinPo" },
{ 150, 150, 60, 60, false, 0x000000 },
{ 390, 150, 60, 60, false, 0x000000, 0xCBC3E3, "Skills", "killMe" },
{ 270, 150, 60, 60, false, 0x000000 }
void displayButtonControls( int index, bool pressed );
// Check if touch is inside button
int findButton( int16_t xpos, int16_t ypos ) {
int nButtons = sizeof(buttons) / sizeof(button);
for( int index=0;index < nButtons;index++) {
button *pButton = &buttons[ index ];
if( xpos < pButton->xpos || xpos > (pButton->xpos + pButton->width) )
continue;
if( ypos < pButton->ypos || ypos > (pButton->ypos + pButton->height) )
continue;
return(index);
return (-1);
// Init button states
void initButtons() {
buttons[index].state = false;
// Screen has been touched
void userTouchCallbackPressed() {
int index;
int xpos = Brain.Screen.xPosition();
int ypos = Brain.Screen.yPosition();
if( (index = findButton( xpos, ypos )) >= 0 ) {
displayButtonControls( index, true );
// Screen has been (un)touched
void userTouchCallbackReleased() {
int index;
// clear all buttons to false, ie. unselected
//initButtons();
// now set this one as true
buttons[index].state = !buttons[index].state;
displayButtonControls( index, false );
displayButtonControls( 1, false );
displayButtonControls( 2, false );
displayButtonControls( 3, false );
// Draw all buttons
void displayButtonControls( int index, bool pressed ) {
vex::color c;
Brain.Screen.setPenColor( vex::color(0xFFB6C1) );
for(int i=0; i<sizeof(buttons)/sizeof(button); i++) {
//for(button b:buttons) {
c = buttons[i].state ? buttons[i].onColor : buttons[i].offColor;
Brain.Screen.setFillColor( c );
// button fill
if( i == index && pressed == true )
Brain.Screen.drawRectangle( buttons[i].xpos, buttons[i].ypos, buttons[i].width, buttons[i].height, c );
else
Brain.Screen.drawRectangle( buttons[i].xpos, buttons[i].ypos, buttons[i].width, buttons[i].height );
// outline
Brain.Screen.drawRectangle( buttons[i].xpos, buttons[i].ypos, buttons[i].width, buttons[i].height, vex::color::transparent );
// draw label
Brain.Screen.setFont(fontType::mono15);
if( buttons[i].labelOn != NULL && buttons[i].state)
Brain.Screen.printAt( buttons[i].xpos + 8, buttons[i].ypos + buttons[i].height - 8, buttons[i].labelOn );
else if( buttons[i].labelOff != NULL && !(buttons[i].state))
Brain.Screen.printAt( buttons[i].xpos + 8, buttons[i].ypos + buttons[i].height - 8, buttons[i].labelOff );
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
Drivetrains.setStopping(coast);
punch1.setStopping(coast);
punch2.setStopping(coast);
wings.set(false);
rightArm.set(false);
leftArm.set(false);
lift1.set(false);
lift2.set(false);
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
//Global odom values
double theta{0.0};
double x_pos{0.0};
double y_pos{0.0};
void autonomous(void) {
waitUntil(Brain.Timer > 1000);
Brain.Timer.clear();
bool LSimple = buttons[0].state;
bool RSimple = buttons[1].state;
bool LHard = buttons[2].state;
bool RHard = buttons[3].state;
bool WinPoint = buttons[4].state;
bool skills = buttons[6].state;
if (skills) {
killMeNow();
} else if (LSimple){
leftSimple();
} else if (RSimple) {
rightSimple();
} else if (WinPoint) {
winPoint();
} else if (RHard) {
rightHard();
} else if (LHard) {
leftHard();
// Insert autonomous user code here.
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
//Remote
bool RemoteControlCodeEnabled = true;
// define variables used for controlling motors based on controller inputs
bool Controller1LeftShoulderControlMotorsStopped = true;
bool Controller1RightShoulderControlMotorsStopped = true;
bool Controller1UpDownButtonsControlMotorsStopped = true;
bool DrivetrainLNeedsToBeStopped_Controller1 = true;
bool DrivetrainRNeedsToBeStopped_Controller1 = true;
void prints() {
while(true){
Controller1.Screen.clearLine( 1 );
Controller1.Screen.setCursor( 1, 1 );
Controller1.Screen.print("L: %4.1f R: %4.1f D: %4.1f", punch1.temperature(fahrenheit), punch2.temperature(fahrenheit), (RightDriveSmart.temperature(fahrenheit)+LeftDriveSmart.temperature(fahrenheit))/2);
wait(300, msec);
void usercontrol() {
// Brain.Screen.print( " x: %4.0f y: %4.0f z: %4.0f", , launch.position( rev ) );
RightDriveSmart.setStopping(coast);
LeftDriveSmart.setStopping(coast);
// process the controller input every 20 milliseconds
// update the motors based on the input values
while(true) {
// inertialMain.installed();
Drivetrains.setTurnVelocity(40, velocityUnits(pct));
wait(40, msec);
punch1.setVelocity(100, percent);
punch2.setVelocity(100, percent);
if(RemoteControlCodeEnabled) {
// calculate the drivetrain motor velocities from the controller joystick axies
// left = Axis3 + Axis1
// right = Axis3 - Axis1
int drivetrainLeftSideSpeed = Controller1.Axis3.position() + Controller1.Axis1.position();
int drivetrainRightSideSpeed = Controller1.Axis3.position() - Controller1.Axis1.position();
// //Forward speed with current joystick scaling
// double Drivespd = Axis3 * (pow(M_E, -d / 10) + pow(M_E, (std::fabs(AxisB) - 100) / 10) * (1 - pow(M_E, -d / 10)));
// //turn speed (from other joystick) with joystick scaling
// double Turn = Axis1 * (pow(M_E, (std::fabs(AxisA) - 100) * t / 1000));
// leftMotorA.spin(reverse, (Drivespd - Turn)*1.27, pct);
// rightMotorA.spin(forward, (Drivespd + Turn)*1.27, pct);
// leftMotorB.spin(reverse, (Drivespd - Turn)*1.27, pct);
// rightMotorB.spin(forward, (Drivespd + Turn)*1.27, pct);
// leftMotorC.spin(reverse, (Drivespd - Turn)*1.27, pct);
// rightMotorC.spin(forward, (Drivespd + Turn)*1.27, pct);
// check if the value is inside of the deadband range
if (drivetrainLeftSideSpeed < 13 && drivetrainLeftSideSpeed > -1) {
// check if the left motor has already been stopped
if (DrivetrainLNeedsToBeStopped_Controller1) {
// stop the left drive motor
LeftDriveSmart.stop();
// tell the code that the left motor has been stopped
DrivetrainLNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the left motor nexttime the input is in the deadband range
if (drivetrainRightSideSpeed < 13 && drivetrainRightSideSpeed > -1) {
// check if the right motor has already been stopped
if (DrivetrainRNeedsToBeStopped_Controller1) {
// stop the right drive motor
RightDriveSmart.stop();
// tell the code that the right motor has been stopped
DrivetrainRNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the right motor next time the input is in the deadband range
// only tell the left drive motor to spin if the values are not in the deadband range
LeftDriveSmart.setVelocity(drivetrainLeftSideSpeed, velocityUnits(pct));
LeftDriveSmart.spin(forward);
// LeftDriveSmart.spin( vex::directionType::rev, 12, vex::voltageUnits::volt);
// only tell the right drive motor to spin if the values are not in the deadband range
RightDriveSmart.setVelocity(drivetrainRightSideSpeed, velocityUnits(pct));
RightDriveSmart.spin(forward);
// check the ButtonR1/ButtonR2 status to control Intake
if (Controller1.ButtonR1.pressing()) {
rightArm.set(true);
leftArm.set(true);
} else if (Controller1.ButtonR2.pressing()) {
leftArm.set(false);
if (Controller1.ButtonL1.pressing()) {
Brain.Screen.clearLine();
launch.spin(forward);
} else {
launch.stop();
if( Controller1.ButtonA.pressing()) {
wings.set(true);
if( Controller1.ButtonB.pressing()) {
wings.set(false);
if( Controller1.ButtonX.pressing()) {
lift1.set(false);
lift2.set(false);
if( Controller1.ButtonY.pressing()) {
lift1.set(true);
lift2.set(true);
if(fire.value() == true) {
launch.spinFor(forward, 385, deg);
Controller1.ButtonRight.pressed(autonomous);
Controller1.ButtonLeft.pressed(twoSeventy);
Controller1.ButtonUp.pressed(zero);
Controller1.ButtonDown.pressed(oneEighty);
Controller1.ButtonL2.pressed(stops);
// wait before repeating the process
wait(20,msec);
// return 1;
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Competition.drivercontrol(prints);
// Run the pre-autonomous function.
pre_auton();
// register events for button selection
Brain.Screen.pressed( userTouchCallbackPressed );
Brain.Screen.released( userTouchCallbackReleased );
// make nice background
Brain.Screen.setFillColor( vex::color(0x000000) );
Brain.Screen.setPenColor ( vex::color(0x000000) );
Brain.Screen.drawRectangle( 0, 0, 480, 120 );
// initial display
displayButtonControls( 0, false );
while(1) {
Brain.Screen.setFont(fontType::mono20);
Brain.Screen.setFont(fontType::mono40);
Brain.Screen.setFillColor( vex::color(0xFFB6C1) );
Brain.Screen.setPenColor( vex::color(0x000000));
Brain.Screen.printAt( 0, 135, " Captcha 621A 0.2.0 " );
this_thread::sleep_for(30);
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
Edit by moderators: We reformatted your code and added code tags so it’s readable, please remember to use them.
