hey my team was wondering what ports to use because the ones in the manual where wrong
Can you please give us a more detailed explanation as to why the manual was wrong?
Can you explain what you mean by the manual was wrong?
Welcome to the forum!
If you select the default drive program (“Drive” from the V5 brain home screen), and then tap on “Wiring”, it will tell you what each port on the brain is assigned to. The left drivetrain motor should go on a port marked “left drive”, the right drivetrain motor on a port marked “right drive”, and for any other motors, choose which port to connect them to based on which buttons you’d like to control them with.
(turns out the new VS Code extension can do screen capture – neat!)
Just forget it we fixed already
Thanks for the help though
