the rules about the programming match?
**1, when the robot start in the programming match ,can student tuch the robot again ? (select program or tuch the bumper)
2,when the robot all back to the start field and stop ,can student change the robot’s direction during the match? (like vex)
3,when the robot stop at the one start field , can the student take the robot to another start field (same side) and start the robot again?**
thank you !
so in the programming match the student can finish one action
and then turn the robot’s direction to continue another action ?Then robot not need to use the graysencer to test the blak line?
if this is legal programming will be easy.
Another quection Ten start fields in the match when first one selected ,and the only one legaly start field can be used?
Student can not change the start field again,during the match?
Yes, but if the student touches the Robot, it must immediately be brought back to a legal starting position in the original Starting Box.
Yes, when you bring the Robot back to a legal starting position, you can place the Robot in any orientation.
[quote=“huangzhonngjian”]
3,when the robot stop at the one start field , can the student take the robot to another start field (same side) and start the robot again?[/quote]
There is only one Starting Box that can be used in the Programming Skills Challenge. I’ve attached an image.
