It appears that you can’t start a thread with a class instance method. Is that correct?
class ObjClass:
__init__(self):
pass
def some_method(self):
pass
obj_instance = ObjClass()
#this gets a runtime exception
sys.run_in_thread(obj_instance.some_method)
#this works fine
sys.run_in_thead(ObjClass.some_method)
Yes. This can be circumvented using a lambda:
class Foo:
def __init__(self):
self.bar = 1
def printbar(self):
print self.bar
a = Foo()
sys.run_in_thread(lambda: a.printbar())
>>> 1
Perhaps more usefully, anonymous functions also let you pass arguments into a thread invocation, which you can’t normally do, since, as you’ve seen, run_in_thread
only takes a function name.
class Foo:
def __init__(self):
self.bar = 1
def printbaz(self, num):
print self.bar + num
a = Foo()
sys.run_in_thread(lambda: a.printbaz(20))
>>> 21
Here’s a V5 mimic project which shows this code in action, executing it in your browser using Javascript. Simply click “play” to run the code.
That’s great. Actually, better than great.
Thanks.
