ThreeWirePort Forward Declaration
I’m having an issue with declaring the ThreeWirePort object to create threewire objects outside robot-config.cpp and robot-config.h.
My goal is for the client to be able to pass the relevant port number for a tracking wheel as an integer in the “Drive” constructor.
This is the Drive constructor as I would want it to look:
Drive::Drive(enum::drive_setup drive_setup, motor_group DriveL, motor_group DriveR, int gyro_port, float wheel_diameter, float wheel_ratio, float gyro_scale, int DriveLF_port, int DriveRF_port, int DriveLB_port, int DriveRB_port, int ForwardTracker_port, float ForwardTracker_diameter, float ForwardTracker_center_distance, int SidewaysTracker_port, float SidewaysTracker_diameter, float SidewaysTracker_center_distance) :
  wheel_diameter(wheel_diameter),
  wheel_ratio(wheel_ratio),
  gyro_scale(gyro_scale),
  drive_in_to_deg_ratio(wheel_ratio/360.0*M_PI*wheel_diameter),
  ForwardTracker_center_distance(ForwardTracker_center_distance),
  ForwardTracker_diameter(ForwardTracker_diameter),
  ForwardTracker_in_to_deg_ratio(M_PI*ForwardTracker_diameter/360.0),
  SidewaysTracker_center_distance(SidewaysTracker_center_distance),
  SidewaysTracker_diameter(SidewaysTracker_diameter),
  SidewaysTracker_in_to_deg_ratio(M_PI*SidewaysTracker_diameter/360.0),
  drive_setup(drive_setup),
  DriveL(DriveL),
  DriveR(DriveR),
  Gyro(inertial(gyro_port)),
  DriveLF(DriveLF_port, is_reversed(DriveLF_port)),
  DriveRF(DriveRF_port, is_reversed(DriveRF_port)),
  DriveLB(DriveLB_port, is_reversed(DriveLB_port)),
  DriveRB(DriveRB_port, is_reversed(DriveRB_port)),
  R_ForwardTracker(ForwardTracker_port),
  R_SidewaysTracker(SidewaysTracker_port),
  E_ForwardTracker(Brain.ThreeWirePort.Port[ForwardTracker_port]),
  E_SidewaysTracker(Brain.ThreeWirePort.Port[SidewaysTracker_port])
  if (drive_setup != ZERO_TRACKER){
    if (drive_setup == TANK_ONE_ENCODER || drive_setup == TANK_ONE_ROTATION){
      odom.set_physical_distances(ForwardTracker_center_distance, 0);
    } else {
      odom.set_physical_distances(ForwardTracker_center_distance, SidewaysTracker_center_distance);
    odom_task = task(position_track_task);
But as we all know, this creates a memory permission error when E_ForwardTracker and E_SidewaysTracker are defined because the Brain and ThreeWirePort haven’t been declared yet (or whatever the reason is).
For whatever reason, this code also gives a memory permission error:
triport ThreeWirePort = vex::triport( vex::PORT22 );
  DriveL(DriveL),
  DriveR(DriveR),
  E_ForwardTracker(ThreeWirePort.Port[ForwardTracker_port]),
  E_SidewaysTracker(ThreeWirePort.Port[SidewaysTracker_port])
    } else {
I also tried making ThreeWirePort a member of the drive class, which gave a memory permission error as well.
Here is some code that doesn’t give a memory permission error:
  DriveL(DriveL),
  DriveR(DriveR),
  E_ForwardTracker(vex::triport( vex::PORT22 ).A),
  E_SidewaysTracker(vex::triport( vex::PORT22 ).C)
    } else {
You’ll notice, though, the the Port[] has been replaced with A and C. For some reason, this method doesn’t allow the client to access ports using integers.
How can I pass the three wire port as an integer? If I’m asking question X when I should be asking question Y, what is that question Y (i.e. how could the code structure as a whole be made better to avoid this problem altogether?)
Here is my code. It’s a template for drivetrain motions that I plan to release publicly in the future, so there should be no problem with including it here:
v5code-project-JAR-Template.zip (52.5 KB)
Thanks!
Josh
It’s all about the order in which constructors are called, you added
in drive.cpp, but the instace of drive actually gets created in main.cpp, presumably before that ThreeWirePort was constructed. So two simple options.
either, something like this.
vex::triport tp1(PORT22);
Drive chassis(
//Specify your drive setup below. There are seven options:
//ZERO_TRACKER, TANK_ONE_ENCODER, TANK_ONE_ROTATION, TANK_TWO_ENCODER, TANK_TWO_ROTATION, HOLONOMIC_TWO_ENCODER, and HOLONOMIC_TWO_ROTATION
//For example, if you are not using odometry, put ZERO_TRACKER below:
ZERO_TRACKER,
and then declare extern tp1 in drive.cpp
drive.cpp partial
extern vex::triport tp1;
  DriveL(DriveL),
  DriveR(DriveR),
  E_ForwardTracker( tp1.Port[ForwardTracker_port]),
  E_SidewaysTracker( tp1.Port[SidewaysTracker_port] )
    } else {
or add a three wire port member to the drive class
class Drive
private:
  float wheel_diameter;
  float wheel_ratio;
  float gyro_scale;
  float drive_in_to_deg_ratio;
  float ForwardTracker_center_distance;
  float ForwardTracker_diameter;
  float ForwardTracker_in_to_deg_ratio;
  float SidewaysTracker_center_distance;
  float SidewaysTracker_diameter;
  float SidewaysTracker_in_to_deg_ratio;
  vex::triport ThreeWire = vex::triport(vex::PORT22);
public:
  drive_setup drive_setup = ZERO_TRACKER;
and then
  E_ForwardTracker( ThreeWire.Port[ForwardTracker_port]),
  E_SidewaysTracker( ThreeWire.Port[SidewaysTracker_port] )
