How does the TM software determine the rankings for 2 teams that were had the same points in qualification rounds?
From Page 17 of the manual:
Teamwork Challenge Rankings
• At the conclusion of each Match, the score will be determined.
o Each Team will receive the points scored for the Alliance Score
• For a Qualifying Match, if no member of a team is present in the driver station at the start of a
Match, that team is declared a “no show” and will receive zero (0) points. A “no show” is
treated exactly the same as a Disqualification. The team’s alliance partner will receive all
points scored in this Match.
• Each team will have the same number of Qualifying Matches
• Points earned for each team in each Qualifying Match are added to get the team’s total
points
• One out of every four (4) Qualifying Matches will not count towards the rankings. If an event
has between four (4) and seven (7) Qualifying Matches per team, then the lowest score for
each team will not be counted. If an event has between eight (8) and eleven (11) rounds, then
the two lowest scores for each team will not be counted. If an event has twelve (12) or more
rounds, then the three lowest scores will not be counted.
• Teams are ranked by total points.
• Ties in ranking are broken by:
o Removing the lowest score from each team’s total and comparing the new total score
o If still tied, the next lowest score will be removed (on through all scores)
o If still tied, teams will be sorted by a random electronic draw
TM uses the rankings criteria described in the game manual:
- Teams are ranked by total points.
- Ties in ranking are broken by: [LIST]
- Removing the lowest score from each team’s total and comparing the new total score
- If still tied, the next lowest score will be removed (on through all scores)
- If still tied, teams will be sorted by a random electronic draw
Thanks all!
