Hey! Does anyone know what the height limit for the tipping point robots unfolded is? My team has looked in the rule book and online resources with little information to be had. I was wondering if anyone on this forum knew the height limit.
Thanks!
Thanks!
There is no height limit, generally the game manual only says what you must do and what you can’t do, so if it’s not in the rulebook it’s generally fair ground.
There isn’t a height limit, but keep in mind that the height limit does not rotate with the robot, meaning that if you tip over and exceed 36 inches in horizontal width, you will have then extended past the legal size.
In the game manual it is under R5 which refers to SG2 for your expansion limits.
only if you purposefully tip over than it is a violation, if it an accident than it is fine
It doesn’t mention intent…
Minor violations of this rule that do not affect or interfere with the Match will result in a warning. Match Affecting offenses will result in a Disqualification. Teams that receive multiple warnings may also receive a Disqualification at the Head Referee’s discretion.
it was said in the Q&A
(correction. it is a violation, but just a warning)
