Tipping Point Questions
First Question, can you put more than 2 moveable bases on the balance area
Second Question, what defines balanced? 180 degrees or just off the ground?
Welcome to the community. Before posting questions about the rules, you should probably take a look at the game manual: https://content.vexrobotics.com/docs/21-22/tipping-point/GameManual.pdf
As you read the game manual, keep in mind that the game manual tell you things that you MUST do, and things that you are PROHIBITED from doing. It can’t tell you everything you might do, so if the game manual does not prohibit an action, then it is legal.
There’s an important section of the game manual that covers definitions, too.
If you still have questions or need clarification after reading the game manual, I’m sure the community will be glad to help.
Just remember to apply G3 as well. Use common sense.
