Ever since the Skyrise season I have been experiencing stalls on my reverse double 4 bar lift with a capacity of 3 cubes. For weeks I have been searching for ways to reduce and minimalise these amounts of stall but none of them helped. It was only until 1 day into World Vex when I applied a considerable amount of lubricant to the joints and axles to ensure that my lift does not stall on the second day. I do know of some tips and tricks of reducing these stalls such as decreasing the amount of friction points, and load weight.
I also went through multiple tests for the Nothing but Net season but ended up using an extensive number of motors for my flywheel mechanism to ensure that it could last for the entire match without stalling.
Before I build the second version of my robot, I was hoping to use few number of motors for a flywheel and a speed base that could afford 4-5 bumps that would not cause it to stall. Could I get some solutions to how to reduce stalls, and are there tricks and different configurations that make things stall less?
Ahh yes, the dreaded PTC trip… You’re not the first to be hit by this.
You already seem to know tip #1 - reduce the torque needs of the motors. You did that by lubricating things as friction is a tricky widget to overcome. That same friction is the thing to avoid in the flywheel.
Tip #4 - let the smart motor library stop you from doing too much current. This may lead to frustration in that the calculations say you are using too much power. But it stops the PTC trips. (Go back to tip 1 at that point to reduce torque needs)
[https://vexforum.com/t/smart-motor-library/22282/1
[Smart Motor Library - Technical Discussion - VEX Forum
