I use PROS and when debugging in the past it has been hard to try and visualize whether the numbers line up, which is why I am interested in graphically debugging. I have seen other teams do it and when I checked PROS documentation there was a section for JINX graphically debugging, but wasn’t out yet. I was wondering if anyone knew any tools for me to graph the changing values of variables?
You could stream the variables to the terminal, using this (make sure u include #include <iostream>
at the top
std::cout << some variable;
std::cout << “ “ << some variable;
Explanation
Cout prints to the terminal. On the second variable, u must use “ “
to create spacing in between the printed variables
then copy all the numbers (ctrl + a, then ctrl + c) to excel or google spreadsheets. Then go to the data tab and split text into columns. Now create a table and see your data.
