How do I insert a torque cartridge into a v5 motor?
Check this out!
make sure you don’t strip the screws on the motor when opening them. If you happen to strip them, you can cut a slot in them and use a flathead to unscrew the stripped screw.
Dont strip, I agree. My tip here is to put pressure down when unscrewing it so it strips less easily
