Tower takrover tray
How i can join first tray with second one …i do not have 45 guests…pictures will be usefull
Thanks in advance
Just use custom cut plates and make a pivot point (cannot send pics right now)
What about fraction?
there are plenty of alternative joints. ones using plates is pretty common. basically just mount the plates like you would a 45 degree gusset, and pick a hole to put the joint on. the wider the joint, the more stages you can fit inside the first and second, but the less compact it is.
some teams use hinges.
