Tray Bot Arm Motors
But yea^^^ screws don’t have to come from vex as long as they’re the same spec vex offers
Ok thank you both. I have a comp on the 14th. But if I’m reading the rules right they have to be 2 inches long no longer correct?
Right and the 2” screw limit is secretly one of the biggest building challenges in vex.
could you not cut the heads off the screws and connect them with standoffs?
They actually make stand-off couplers which are just that, screws with the heads cut off. The 2” limitation is a niche thing that most people won’t have issues with, but when trying to make compact gear boxes with exclusively screw joints or doing long box joint sections, a longer screw would be nice.
