I have seen that many of the good tray bots have now started using this for their tray:
What is the stuff that they have on the tray that the cubes slide on? I can not tell
Zzzzziiiiiiiiiiiiiiiiiiiiiip ties
Is that one Zipties or multiple connected together?
they are single zipties
Where are they fed through?
@CarCar
obviously I don’t know the answer for sure, but probably through the holes in the angle that are closest to the side that the cubes would rest on
Y zip ties tho? I get that u don’t have to use Le an but is it just as effective? Is there any other reason?
I’m not sure since I haven’t used zip ties like that, but I generally see them on 3 stage trays or 2 stage trays with extensions. My assumption is weight savings and the availability of zip ties vs lexan, plus you can only use so much lexan on your bot.
No, Michigan
20 char
Oh, I thought I have seen you guys in ohio
We were at the Kalahari signature event last year
that makes sense
