Trouble with running autonomous V5 code from Vs code
I’m from a team on the newer side of programming with v5. Since we have a six motor drive we’ve been using visual studio code with the vex code extension. So far we had no trouble with the user control code, but when we try running autonomous the robot doesn’t run any of our commands and eithers spins 360 degrees nonstop or drives itself in a straight line forever (or until the end of our field). We have no errors with our code when we build it and have used only functions from the vex library. We would really appreciate any help we could get with fixing our code.
Here is the code:
#include "vex.h"
using namespace vex;
brain Brain;
competition Competition;
controller Controller1 = controller();
//left motors
motor leftMotorA = motor (PORT8, false);
motor leftMotorB = motor (PORT6, false);
motor leftMotorC = motor (PORT12, false);
motor_group leftMotors = motor_group (leftMotorA, leftMotorB, leftMotorC);
//right motors
motor rightMotorA = motor (PORT20, true);
motor rightMotorB = motor (PORT15, true);
motor rightMotorC = motor (PORT3, true);
motor_group rightMotors = motor_group (rightMotorA, rightMotorB, rightMotorC);
inertial Inertial = inertial (PORT1);
digital_out dig1 = digital_out(Brain.ThreeWirePort.A);
motor intakeMotor = motor (PORT13, true);
//define your global instances of motors snd oher devices here
drivetrain Drivetrain = drivetrain (leftMotors, rightMotors,3,361.95,5,mm,1);
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
//void pre_auton(void) {
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
// The autononomous code is written here
void autonomous(void) {
  Brain.Screen.printAt( 10, 50, "Controller1.ButtonA.pressing();" );
  Drivetrain.setDriveVelocity(30, pct);
  Drivetrain.setTurnVelocity(30, pct);
  Drivetrain.driveFor(fwd, 18 , inches);
  wait(20,msec);
  dig1.set(true);
  intakeMotor.spin(fwd, 650, rpm);
  Drivetrain.turnFor(left, 90, degrees);
  wait(20,msec);
  Drivetrain.driveFor(reverse, 24, inches);
  Drivetrain.turnFor(right, 90, degrees);
  Drivetrain.turnFor(right, 135, degrees);
  Drivetrain.driveFor(fwd, 24, inches);
  dig1.set(false);
  Drivetrain.turnFor(right, 180, degrees);
  Drivetrain.driveFor(fwd, 40, inches);
  //Smartdrive.driveFor(fwd, 24, inches);
// Main will set up the competition functions and callbacks.
int main() {
  autonomous();
  // Set up callbacks for autonomous and driver control periods.
  //Competition.autonomous(autonomous);
  //Competition.drivercontrol(usercontrol);
  // Run the pre-autonomous function.
  //pre_auton();
  // Prevent main from exiting with an infinite loop.
  //while (true) {
   // wait(100, msec);
edit: code tags added by mods, please remember to use them.
wheelTravel of 3mm ?
wheelBase of 5mm ?
Sorry for the late reply. I just realized that we have the wheel base and wheel travel of 3 mm and 5mm. These were some calculations errors on our side. I’ll change that in the code, but will help the robot understand directions better? I currently not at the local lab, so I’ll test it later. Thank you for your help, I truly appreciate it.
